Cozza
posted on 30/6/11 at 08:21 PM |
Testing a C20XE
Hi folks,
I have a C20XE redtop mounted with a Manta box in a part-built Locost chassis (bought at this stage). I've been told the engine's good
but before I go any further thinking I want to run it. Does it make sense to get it going with the standard EFi and distributorless ignition? I
don't have an ECU so thinking I'll try to get one from e bay or a scrappy.
Any thoughts/advice much appreciated!
Ben_Copeland
posted on 30/6/11 at 08:38 PM |
If you do go down the testing and buying an ecu. Beware theres several different ones, and they are not compatible.
I'd just get on with the proper installation and then go from there... Instead of spending money that doesnt need spending.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
laptoprob
posted on 30/6/11 at 08:59 PM |
Totally agree....dont even think about the std setup, its not worth it.
http://www.youtube.com/watch?v=ajlF4nWJtGA
Cozza
posted on 30/6/11 at 09:03 PM |
What installation would you recommend? I'm not too worried about tuning the engine, just after a good strong installation. At the moment
I'm not able to spend a lot on it. I understand that the standard EFi is bulky but is it possible to do? Do you know if it's difficult
to get a hold of the correct ECU?
laptoprob
posted on 30/6/11 at 09:08 PM |
I would be looking at either spending the money on a Megajolt and bike carb setup or easier route of twin 45`s and a manifold from YUKSPEED.
If you want to save a bit of cash then have a browse round for an MBE 912 ecu.
Theyre are old now and only worth 40-50 quid or so but most of them will have a good base map for a C20XE(but check that before you buy).
I started with one of them and it ran well with twin DHLA 45`s at about 180bhp with no mods!!
If you want anymore help then give me a U2U, i will be glad to help.
laptoprob
posted on 30/6/11 at 09:10 PM |
Sorry, just had another thought....
If your completely strapped then go for the dizzy off an old 1.6 Cavalier/Astra along with the coil.
Cheap as chips conversion but a little hard to find.
Beware though you need to make sure the engine is the old version which will accept the drive for the dizzy on the end of the cam.
Cozza
posted on 30/6/11 at 09:23 PM |
Thanks for your help! I'll have a bit of a look around on the web for MBE 912's and also old Astra/Cavalier dizzies. Might come back to
you............
Cheers!
laptoprob
posted on 30/6/11 at 09:28 PM |
autograss vauxhall distributor redtop setup complete | eBay UK
