JekRankin
| posted on 12/7/11 at 07:55 AM |
Wanted: Simple part made on lathe
Good morning,
I'm looking to employ the services of someone to make up the following part in a bushing plastic like nylon or nylatron for me. Qty required:
just one! Anyone out there able to offer their services?
Many thanks,
Jek
  Clutch bush
minitici
| posted on 12/7/11 at 08:04 AM |
I could knock one of these bushes up from Nylon66 bar.
I may not be able to hold the tolerance on the 8mm bore, otherwise looks fairly easy.
Doug.
JekRankin
| posted on 12/7/11 at 08:38 AM |
Sounds ideal, you have u2u!
Jek
minitici
| posted on 12/7/11 at 09:29 AM |
  nylon bush
Hi Jek - close approximation of your bush made!
I'll pop it in the post.
Doug.
Confused but excited.
| posted on 12/7/11 at 09:57 AM |
Now that has to be some sort of record, even for LCB!
craig1410
| posted on 12/7/11 at 10:37 AM |
Respect indeed!
| posted on 12/7/11 at 10:49 AM |
Outstanding work
JekRankin
posted on 12/7/11 at 11:11 AM |
Wow! Many many thanks Doug!! That was amazingly quick!
JekRankin
| posted on 17/7/11 at 05:47 PM |
This weekend I made it home to find a parcel waiting for me containg one complimentary nylon bush! The part fitted perfectly and I now have a working
clutch! This isn't the first time I've been hugely impressed by the generosity and helpfulness of the members on here! Thanks again
Doug!
Talking of freebies, I have a couple to give away myself. Both items posted free to whoever wants them:
1. One pair of steel steering rack clamps and standard rubber bushes to suit a mk2 Escort rack. The steel clamps were, I think, originally supplied by
Tiger, and will need the mounting holes drilled in them (and painted too). Not the lightest clamps I've seen, but good for a builder on a
budget.
2. One copy of the Haynes Car Builders Manual. Given to me, free of charge by locostbuilders member londonsean69 - I've now finished with it, so
I'm passing it on! Its a fairly basic and generic guide, but suitable for a novice as an introduction to building cars.
Jek
[Edited on 17/7/11 by JekRankin]
