Author: Subject: Which ECU?
Cozza
posted on 30/8/11 at 08:58 PM Reply With Quote
Which ECU?
I've got a part-built kit with a red top but without an ecu. How do I know which one I need? It's got a dispac on it but I don't know which Vauxhall the engine came out of.
[Edited on 30/8/11 by Cozza]
Ben_Copeland
posted on 30/8/11 at 09:06 PM Reply With Quote
Are you running original injection or carbs/throttle bodies?
If the first you could get a ECU M2.8 from a later Astra gsi
if second, most aftermarket ecus might be ok... Megasqurt/jolt. once again depends if carbs or tbs?
Ben
Locost Map on Google Maps
Enter Your Details Here
Cozza
posted on 30/8/11 at 09:13 PM Reply With Quote
Thanks. Is that the only one that will work?
RK
posted on 31/8/11 at 02:40 AM Reply With Quote
go with whatever stock was to begin with. Once you start using aftermarket ECU's, you have more in that than your engine. I know I do.
Ben_Copeland
posted on 31/8/11 at 06:57 AM Reply With Quote
Yes if you have stock engine with original injection then that's the ecu. The earlier ecu worked with distributor.
Ben
Cozza
posted on 31/8/11 at 04:22 PM Reply With Quote
OK. Thanks very much!
Cozza
posted on 31/8/11 at 04:33 PM Reply With Quote
What about an ecu from a Cavalier GSi?
Ben_Copeland
posted on 31/8/11 at 04:34 PM Reply With Quote
Maybe a later one.. but my cavalier gsi was dizzy not dizzyless and not turbo one either obviously
Ben
posted on 31/8/11 at 05:08 PM Reply With Quote
All of the distributor-less C20XEs would have been fitted with a cat and oxygen sensor wouldn't they? Can you run them with this disconnected without it throwing error codes and possibly limp home mode?
Ben_Copeland
posted on 31/8/11 at 08:02 PM Reply With Quote
If he;s IVA'ing it, he'll probably need cat and lambda anyway
Ben
Cozza
posted on 31/8/11 at 08:15 PM Reply With Quote
I've got a cat already - in the custom made exhaust. Where in the system should the lambda sensor go?
Ben_Copeland
posted on 31/8/11 at 08:19 PM Reply With Quote
Just after the last collector, before the CAT
Ben
