Author: Subject: Problems with a part-build
Cozza
posted on 4/9/11 at 08:21 PM Reply With Quote
Nightmare. I'm just getting my head round what I've got in my part-build (red top c20xe with a Manta gearbox). I've discovered two major problems:
In order to avoid the bottom of the inlet manifold interfering with the steering column, the previous owner has sliced the bottom of the manifold off!! There's a 1 inch square hole at the bottom.
The gearbox casing is touching the vertical rail to the left of where the pedal box would go/to the right of the front of the transmission tunnel.
Can anybody offer any advice or reassurances?
NigeEss
posted on 4/9/11 at 09:54 PM Reply With Quote
Post some pics, they tell a thousand words...
Cozza
posted on 5/9/11 at 06:52 AM Reply With Quote
Ok. I'm off to work now but will put them up tonight. Cheers'
Ben_Copeland
posted on 5/9/11 at 11:41 AM Reply With Quote
Id strongly suggest binning the standard injection system and going bike throttle bodies or similar. More power and much easier to fit.
Also sounds like either the engine isn't central in the tunnel or it's too far back into the tunnel. I'll await the pictures to make my final comments
Ben
Locost Map on Google Maps
Enter Your Details Here
Cozza
posted on 5/9/11 at 06:11 PM Reply With Quote
http://i981.photobucket.com/albums/ae297/CozzaNess/DSCN0699.jpg?t=1315246757
http://i981.photobucket.com/albums/ae297/CozzaNess/th_DSCN0697.jpg?t=1315246757
The first pic shows the gearbox housing fouling the upright.
The second pic (taken upside down) shows the bottom of the inlet manifold with an approx 1" square section removed!
Any thoughts?
[Edited on 5/9/11 by Cozza]
Ben_Copeland
posted on 5/9/11 at 06:20 PM Reply With Quote
Originally posted by Cozza
[img]G/DCIM/100NIKON/DSCN0697[/img]
[img]G/DCIM/100NIKON/DSCN0699[/img]
Any thoughts?
U need to upload them to the Photo archive first !
Ben
Cozza
posted on 5/9/11 at 06:21 PM Reply With Quote
Sorry. I've re-done them with a link to Photobucket
Ben_Copeland
posted on 5/9/11 at 06:26 PM Reply With Quote
Errr from what i can tell the engines too far into the transmission tunnel or too far over to one side.
The inlet manifold is cast so a real pain if you want to weld it. I'd still go with the replacing with carbs/ tb's
Ben
