Author: Subject: WTD: R1 loom plug from stator to reg/rectifier
hobbsy
posted on 17/12/11 at 07:24 PM Reply With Quote
As per the subject.
I need the 3 pin grey connector which is about 2 inches wide and 1 inch deep. It goes from the stator windings (hard wired) on plugs on to the regulator / rectifier.
It would be a major bonus if it had a decent length of wire left on it as well.
This is for the 2002/2003 5PW engine however I suspect the earlier 4XV / 5JJ may be the same. I'd guess the later 5VY is different though?
Thanks.
lsdweb
posted on 18/12/11 at 10:47 AM Reply With Quote
Can you post a photo of the rectifier / regulator? I may have one.
Regards
Wyn
NigeEss
posted on 18/12/11 at 11:51 AM Reply With Quote
Is it the plug from the stators or the plug into the loom you need ?
If it's the former I have one still attached to a dead stator.
hobbsy
posted on 18/12/11 at 04:05 PM Reply With Quote
Wyn - don't have a reg/rect photo to hand, and just to be clear its the plug and length of cable going to the stator I need.
Nige - as above it's the cable that is attached to the stator going to and including the grey 3 pin plug that attaches to the AC side of the reg/rect that I need. If you have this on a dead stator then I'm interested (please leave as much cable as possible on it as my reg rect is a fair distance away from the stator). U2U me with how much you want for it inc post?
Thanks guys.
matt_gsxr
posted on 18/12/11 at 05:38 PM Reply With Quote
I think you may need these guys for your Furukawa connector.
The only problem is that they charge high postage from USA
http://easternbeaver.com/Main/Elec__Products/Connectors/R_R_Connectors/r_r_connectors.html
If you find the same cheaper then I'd be interested in hearing about the supplier as I need one similar but am too tight to pay massive postage.
matt_gsxr
posted on 18/12/11 at 05:40 PM Reply With Quote
or (as I just did) search Furukawa on e-bay.
hobbsy
posted on 18/12/11 at 08:58 PM Reply With Quote
Matt,
Which one's were you looking at on eBay when I narrowed it with fuku connector I only got 2 hits.
Didn't realise it was a connector common across different makes of bike. Useful to know.
NigeEss
posted on 18/12/11 at 09:38 PM Reply With Quote
Hobbsy,
I don't want anything for it as it was for the bin anyway. Was just sitting in my scrap pile
waiting to be weighed in. I'll cut as close to the stator as I can.
UU me an address and I'll pop it in the post.
