ChrisLeary
| posted on 20/12/11 at 10:05 PM |
Flat side oval tube
Evening all,
I need to remake my front wishbones as I've spotted a bend in one of mine. I'd like to make them out of flat sided oval tube. Does anyone
know of any suppliers? I've looked at Ralt, but they only do the aero stuff and apparently it comes at a price.
Thanks in advance.
Chris
austin man
| posted on 20/12/11 at 10:13 PM |
MK Sportscars do oval tube for their wishbones
designer
| posted on 20/12/11 at 10:28 PM |
Any oval tube will do, it does not have to be flat sided.
bi22le
| posted on 20/12/11 at 10:31 PM |
Plenty of stuff about in steel.
I think a search for steel extension stockists will help.
Please read my ring story:
ChrisLeary
| posted on 20/12/11 at 10:49 PM |
Thanks for the replies so far. I've had a look at a couple of steel stockists and not really had much luck to be honest. I'll have a scout
around again tomorrow, see what I can find. I'll probably try and give MK a ring and see what they can do for me.
Thanks again,
Chris.
designer
| posted on 20/12/11 at 10:59 PM |
You can get it anywhere!!
http://www.cherinproducts.co.uk/tubes.htm
http://www.applegate.co.uk/all-industry/products/oval-steel-tube-0093234.htm
http://www.preferredtubes.co.uk/
gazza285
| posted on 21/12/11 at 01:57 AM |
quote: Originally posted by ChrisLeary
Evening all,
Thanks in advance.
Chris
The question to ask is why would you want to make your bones out of flat sided oval tube?
| posted on 21/12/11 at 10:22 AM |
Probably because he likes them. I got some from MK when Martin was still there and it works fine.
ChrisLeary
| posted on 21/12/11 at 10:26 AM |
Evening all,
Thanks in advance.
Chris
Well why not? IMO they look good.
Cheers, chris
TimC
| posted on 21/12/11 at 10:33 AM |
ADR do lovely end fittings for their 30 x 15 oval tube. The only issue is that the tube is only 1.5mm wall so it might not be deemed suitable for an
arm that is supporting a lover shock mount and the force that comes with that.
Myke 2463
| posted on 21/12/11 at 11:27 AM |
Check https://randallmotorsport.ssl-01.com/product_info.php?cPath=71&products_id=545
Be Lucky Mike.
