garybee
| posted on 26/2/12 at 01:08 PM |
zetec temp sensor plug
Does anyone have a plug to connect to a silvertop Zetec temp sender (the one on the top of the thermostat housing)? I have a few looms but none seem
to have this type of plug on (the round type).
Also after a plug for the Inlet Air Temp sender (round type as well).
Thanks in advance
Gary
tims31
| posted on 26/2/12 at 02:02 PM |
Sorry Gary I don't have a spare temp sender but see you said you have a few looms. I don't suppose you have any spare ecu looms for a
blacktop with 104 pins.
Good luck finding a temp sender anyhow
Build: http://www.martinsfurybuild.co.uk/
garybee
| posted on 26/2/12 at 07:26 PM |
Hi tims,
It's not the sender i'm after, just the plug that connects to it (just clarifying for anyone who might be reading).
Anyway, I do have an engine loom for a 104 pin ECU. Do you need the injector loom that connects to it aswell?
tims31
| posted on 26/2/12 at 09:38 PM |
Hi Gary,
I'm not sure of the state of my injector loom so if you have one of those too that would be great.
Where abouts are you in Lincolnshire?
I live in Spalding but work in Lincoln
garybee
| posted on 27/2/12 at 12:38 AM |
I'm in Ruskington (just outside of Sleaford), so pretty much on your commute.
tims31
| posted on 27/2/12 at 01:06 PM |
I pass Ruskington every day on the A15 so can pop in on my way home one day if your around - Have sent you a U2U
[Edited on 27/2/12 by tims31]
