Author: Subject: WTD: Pinto cambelt cover bolts
James
posted on 17/5/12 at 06:33 PM Reply With Quote
If my Pinto ever had them I've managed to lose the special bolts that hold the cambelt cover on.
Has anyone got theirs kicking around somewhere that they'd like rid of?
I *think* there's 3 or 4 of them (or certainly the cover has 4 bolt holes). 2 go just beneath the cam pulley, 1 goes down low near the sump. There's another (I think!) up above-left the crank pulley.
I tried replicating with a piece of threaded bar and lock nuts but it was ridiculously hard to get the cover on!
Anyone?
James
[Edited on 17/5/12 by James]
posted on 17/5/12 at 06:35 PM Reply With Quote
If you get stuck you may be able to use normal bolts with a small spacer ton replicate the shoulder
nilocp
posted on 17/5/12 at 06:54 PM Reply With Quote
I will have some amongst my bits, but can you remember exactly what they look like? I think M6 with an inbuilt washer, and where they blue ones??
Colin
James
posted on 17/5/12 at 07:04 PM Reply With Quote
Colin
Copied from another recent post:
James
mcerd1
posted on 17/5/12 at 07:08 PM Reply With Quote
don't think I've got a spare set, but I've got some I can measure if needed....
nilocp
posted on 17/5/12 at 07:33 PM Reply With Quote
Aah you didnt mean the bolts, you meant the things that the bolts go into!!!
Yes I have some of those I am sure. How many of those are there?
jollygreengiant
posted on 17/5/12 at 10:27 PM Reply With Quote
3, the fourth bolt just goes into a threaded hole on the block/lower cover.
James
posted on 18/5/12 at 12:31 AM Reply With Quote
I only need 1! :)
Went to the garage this eve. Spent ages hunting through old biscuit tins of bolts etc.
Found the lower left 'bolt' and one of the top ones.
That just leaves one of the top ones, as JGG says, the lower right is a normal bolt.
James
mcerd1
posted on 18/5/12 at 11:58 AM Reply With Quote
I'll have a look at the weekend....
James
posted on 21/5/12 at 03:04 PM Reply With Quote
Big thanks to Nilocp who sent me the bolt I needed in the post. Arrived this morning!
Thank you!
James
