AndyW
| posted on 21/6/12 at 06:50 PM |
32mm ID mild steel pipe about 500mm
Hi all
I seem to be having a run of bad luck. Every time i order something the wrong thing turns up. I am in need of a small length of mild steel tube with
an ID of 32mm (to make a water pipe from)
Does anyone have an off cut anywhere that they want rid of??
Please let mew know as a small job such as plumbing in the cooling is more trying that re-wiring the eec-v ecu from the ford
Davg
| posted on 21/6/12 at 07:24 PM |
Alloy aerial pole from b&q
AndyW
| posted on 21/6/12 at 07:33 PM |
needs to be mild steel so two outlets can be welded to it...
big_wasa
| posted on 21/6/12 at 07:48 PM |
You want an OD of 32mm or 1 1/4"
somthing like 1 1/4'(O/D), 32mm Mild Steel Exhaust Pipe, 50cm, Tube | eBay
1 1/4'(O/D), 32mm Mild Steel Exhaust Pipe, 50cm, Tube should do the job.
Give me a shout if you need a hand with the spurs welding on.
silverback
| posted on 21/6/12 at 07:50 PM |
I have just had a look in my stock and the nearest I have got to the size your after is 28.2 i/d. If that is ok let me know.
Regards
Mick
AndyW
| posted on 21/6/12 at 08:47 PM |
Warren,
thants the exact e-bay link that I got one from trouble is the pipe that turned up today is 28mm OD so too small
silverback
| posted on 21/6/12 at 08:57 PM |
Just measured o/d and is 30mm. That is the closest I can get. I will try my dealer who supplies me and see if he has got some i stock. Will let you
know tomorrow.
Mick
silverback
| posted on 22/6/12 at 09:56 AM |
Just got back from metal suppliers and the closest they do would be 34 i/d with a4mm wall taking it to 42mm o/d.
I think best thing would be to go to an exhaust dealer, they might be able to help.
Mick
whitestu
| posted on 22/6/12 at 10:43 AM |
This is what I used for my water pipe. Very Locost but not sure if the chrome persents a problem for welding though.
HENRY 'Numatic' EXTENSION ROD TUBE CHROME- HOOVER VAX | eBay
Stu
AndyW
| posted on 22/6/12 at 02:50 PM |
Stu
Got that for one of the pipes, but that cant easily be welded...tried that too......
need mild steel...............
owelly
| posted on 22/6/12 at 03:11 PM |
I have a piece that is 30mm i/d. It's probably not quite 500mm and has a slight bend in it. It's the bottom of a bunk bed ladder from
IKEA.
http://www.ppcmag.co.uk
big_wasa
| posted on 22/6/12 at 04:52 PM |
quote: Originally posted by AndyW
Warren,
Not as advertised then, I would ask for another bit with the advertised od.
