Author: Subject: Duratec crank sensor alignment tool
redeye
posted on 25/7/12 at 09:11 AM Reply With Quote
As above really
I need a Duratec crank sensor alignment tool.
Can anyone lend me one and Ill send it back once Im done?
Patrick
big-vee-twin
posted on 25/7/12 at 09:45 AM Reply With Quote
Just make sure the sensor aligns in the middle of the pin, you can make fine adjustments within the tuning software your using.
http://www.triangleltd.com
ashg
posted on 25/7/12 at 12:15 PM Reply With Quote
take cylinder 1 spark plug out get the engine to tdc. then line the sensor up in the middle of the tooth.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
redeye
posted on 25/7/12 at 02:26 PM Reply With Quote
Cheers for the advice guys
Ill try this tonight
Im using Omex 600 and hoping to have it fired up this week, fingers crossed
Tiger Super Six
posted on 25/7/12 at 03:43 PM Reply With Quote
You don't need the engine at TDC to put a new crank sensor on, you just need to line it up properly.
Mark
Tiger Avon
big-vee-twin
posted on 25/7/12 at 05:31 PM Reply With Quote
I asked a while ago to borrow an alignment tool, got the same response as you, So I best guessed the sensor position, the engine fired up straight away.
I didn't set the engine to TDC first just aligned the sensor centrally on one of the teeth, if it lines up on one, it lines up on them all.
Tiger Super Six
posted on 26/7/12 at 12:32 PM Reply With Quote
You would only need the engine TDC if you were setting the engine timing and then putting the trigger wheel on. There is a marked tooth that ends up about 11o'clock if I remember rightly.
To put the sensor on as mentioned you just need to line it up with the trigger wheel, no need to set to TDC.
[Edited on 26/7/12 by Tiger Super Six]
Mark
Tiger Avon
neilp1
posted on 26/7/12 at 01:52 PM Reply With Quote
I started mine today using Omex 600. I just fitted the crank pos sensor and didn't even check the TDC as I bought the engine but didn't remove any of the internals or the pulley.
Mind you as I was about to turn the key I did think about it!!! But it started, thank the lord!!
