Apollo1600
| posted on 20/8/12 at 02:25 PM |
Wanted carb balancer
Hi there,
Im after a carb balancer for some dcoe webers.
maccmike
| posted on 20/8/12 at 02:32 PM |
Iv made my own this morning.
its a four pot four carb but only using 2 guages. left 2. right 2. then middle 2.
2 guages off ebay £9.
couple unions £5
1 mtr hose £pennies.
works perfect. got to squeeze the hose slightly to limit flutter but jobs a good'n.
Thjere something like £60 for a 4 guage set up.
splitrivet
| posted on 20/8/12 at 02:34 PM |
You dont really need one, a bit of hose and your lug holes will do it, if your deef you may find it difficult though.
Bob
Apollo1600
| posted on 20/8/12 at 02:35 PM |
Thanks for the info, im ideally after the one that pushes into the actual trumpet.
| posted on 20/8/12 at 02:43 PM |
With DCOE carbs the hose to the ear method is best, the only thing to make sure the carb end of the hose is held in exactly the same position
relative to the carb trumpet.
Macbeast
| posted on 20/8/12 at 04:23 PM |
Link just takes me to eBay, not to the gauges
loggyboy
| posted on 20/8/12 at 04:28 PM |
No link was posted, if you type ebay the new dodgy forum software adds a basic link...
Mistral Motorsport
Macbeast
| posted on 20/8/12 at 04:43 PM |
Oh I see. Thanks
maccmike
| posted on 20/8/12 at 06:04 PM |
Bob
I read its too unreliable, might try it tho.
Ps I accidently pressed report and not quote so my apologis
Confused but excited.
| posted on 20/8/12 at 06:31 PM |
couple unions £5
Surely (only IMHO of course) you would balance the middle two first then match up the outside ones to those.
If you do left two, then right two, then balance the middle two, the outside two would then be out of balance with the inner two. Always assuming that
you had to adjust the inner two of course.
I also would like to know where on ebay to get two gauges for that price. I couldn't find any.
[Edited on 20/8/12 by Confused but excited.]
jacko
| posted on 20/8/12 at 06:42 PM |
couple unions £5
This is right on bike carbs
Jacko
whitestu
| posted on 20/8/12 at 08:13 PM |
You can't beat a Morgantune is you have vacuum take offs on each inlet. They aren't cheap though.
Stu
Westy1994
| posted on 20/8/12 at 08:42 PM |
quote: Originally posted by Apollo1600
Hi there,
You dont say where you are, but if you are local to me you can borrow mine, although it does not attach to the trumpets,
pic attached.
maccmike
| posted on 20/8/12 at 09:54 PM |
couple unions £5
Hia mate. Its a bike. You sync 1+2. Then 3+4, or other way round, doesnt matter. Then by syncing 2+3 all 4 are equal.
Il find them then u2u you
maccmike
| posted on 20/8/12 at 09:58 PM |
Vacuum Gauge New 50mm -1/0 Bar 1/8 BSPT Bottom connection | eBay
