blakep82
| posted on 31/8/12 at 12:27 AM |
WTD: various parts people may have left over
i'm after a few odds and ends, various different things, which hopefully people might have left over from their own builds
first up, some sort of rubber edge trim, the sort of thing you push over the end of a metal panel. i've got a stainless sort of gueard under my
fuel tank, i cut a small hole in it for access to a fuel tap thinking it was aluminium, now its got very sharp edges that keeps burning out cutting
discs and sanding drums. onle really need sort of 15cm or so for that, but could also do with some for my header tank bracket, which is quite big.
possibly up to 1m for that?
2nd, i've got a sparco steering wheel with 6 mounting holes, but nothing to fill the centre hole with. any old or broken horn push things going
about? or is there some sort of aluminium sandwhich plate thing that goes between the wheel and the hub, and has a raised centre to fill the centre?
or some sort of IVA pad to go over it?
terrible pic of the wheel, but you get the idea
next mirrors, not a huge fan of these mirrors, they wouldn't really be my choice, but they meet all my requirements, and possibly best of a bad
bunch. I don't really like any mirrors i've seen yet
http://www.cbsonline.co.uk/product/Universal_Mirrors_White_M04WH
not really after alternatives, i just don't like cbs postage prices
if theres a spare 4 cylinder ford coil pack plug going, i might be interested too.
i could maybe do with some rubber lined P clips to go round my axle, the axle tube is 70mm diameter, i guess i'd be looking for doubling up
35mm ones, so 8 of those should do it?
anyone got any of these things in their way?
________________________
mcerd1
| posted on 31/8/12 at 09:49 AM |
which type are you after, the early ones or the later ones ?
early ones:
later ones:
blakep82
| posted on 31/8/12 at 09:52 AM |
ooh, later one, but its only the plug i'm after just now, thought the plugs were the same?
mcerd1
| posted on 31/8/12 at 10:14 AM |
^^ opps, yes they are the same plugs (off to get more coffee and re-check those drawings I just sent to the customer )
