Apollo1600
| posted on 29/12/12 at 03:40 PM |
Wanted
Im after a couple of bits for my pinto. Ive got a fixed fan but need a waterpump and pulley and all the fixings. I also need the bolts and nuts and
bushes that screw into the block and head to mount the cam belt cover. Also after all the brackets to mount the alternator.
richardm6994
| posted on 29/12/12 at 04:00 PM |
This might help for the alternator bracket;
http://www.rhocar.org/index.php?showtopic=35455&st=15
| posted on 29/12/12 at 05:36 PM |
Ford Sierra water pumps are about £15 new, not worth scrounging for and the pulley is part of your fan which you have already isn't it ? Mine
had a viscous fan with a left hand thread nut holding it and 4 m8 bolts to the pump spindle.
Apollo1600
| posted on 29/12/12 at 07:59 PM |
Thanks for the replies, I need the pulley in order to drive the alternator.
snippy
| posted on 29/12/12 at 09:21 PM |
This was the pulley on my alternator on my Pinto set up. Is this what you need?
Apollo1600
| posted on 29/12/12 at 10:31 PM |
It was this pulley i was after if possible.
Genuine Ford Mk2 Escort RS2000 Water pump pulley 2 litre Pinto engine
