Furyous
| posted on 31/12/12 at 10:51 PM |
WTD: Someone in Reading with a Solid Vice
I'm having a lot of trouble undoing the nut on my alternator pulley. I've tried clamping the pulley in my work mate but I just bent the
work mate. I'm running out of ideas aside from borrowing a solid bench vice for five minutes.
Does anyone have one I could use quickly, or have any suggestions on how to undo it?
I've tried a torx bit in the middle of the shaft with a spanner on the nut but that hasn't worked.
[Edited on 31/12/12 by Furyous]
loggyboy
| posted on 31/12/12 at 11:03 PM |
Not a reverse thread is it?
Mistral Motorsport
dave r
| posted on 31/12/12 at 11:12 PM |
air or battery impact gum
will have it off in seconds
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
Furyous
| posted on 31/12/12 at 11:35 PM |
There's a little thread showing and it's definitely a standard thread.
...Does anyone have an impact gun I can borrow?
spiderman
| posted on 1/1/13 at 02:10 AM |
Place an old fan belt around the pulley and using either a vice or some mole grips hold the fan belt tight around the pulley.
If you don't have a suitable vice drop the slack part of the fan belt down through your workmate and hold it tight with the mole grips, if you
don't have any of those try putting something large and round into the loop that hangs down below the workmate. If that fails put it back on the
car on it's slackest position with the fan belt on and wind some small rope or cord around the fan belt before and after the pulley so that it
tightens more and more as you keep winding the rope round and round.
I hope that all makes some sense and is of some help.
Happy New year to you and yours
Spider.
Spider
steve m
| posted on 1/1/13 at 02:56 AM |
The only time i had to do this, was put the alternator back on the car, with the fan belt as tight as poss, then put a ring spanner on the nut, and
wack the other end of a spanner with a hammer the way to undo,
steve
| posted on 1/1/13 at 09:26 AM |
A decent impact wrench will have it of in seconds, more importantly , safely
w4lrus
| posted on 1/1/13 at 09:09 PM |
I have a vice, and a battery impact gun, and I live in Caversham, if that helps?
stevebubs
| posted on 2/1/13 at 10:48 AM |
If w4lrus is a no-go, let me know and I'll investigate how easy it is to get into my garage...not been in there for a while and the kids and
Missus have been using it as a dumping ground..
[Edited on 2/1/13 by stevebubs]
Furyous
| posted on 2/1/13 at 01:21 PM |
I'm visiting w4lrus tonight so hopefully we can get it sorted.
motorcycle_mayhem
| posted on 2/1/13 at 03:39 PM |
....in desperation, given the locost tool selection, cut the nut with a hacksaw?
Impact air gun will shift just about anything, except 49 year old land rover leaf spring nuts...
Furyous
| posted on 2/1/13 at 08:01 PM |
Thanks to w4lrus, I had the nut off in a few seconds using his impact wrench.
