peter030371
| posted on 4/1/13 at 08:57 AM |
WTD Mk2 Escort steering column
Has any one got a Mk2 Escort steering column tucked away in 'that pile' at the back of the garage they no longer need? I believe two types
have been used on the Mk2 Escort but mine is 0.7" in diameter (including a coat or two of paint!)
Only really need the inner part as it's to replace the one already fitted on my Striker that is now worn due to the play on the 15 year old
quick release adapter
As I will be welding a new adapter to it I am not even concerned if the steering wheel end is a little damaged
aerodynamix
| posted on 4/1/13 at 07:51 PM |
Column inner
Is this any good to you : new column inner
peter030371
| posted on 5/1/13 at 10:52 AM |
mmmm, not sure..... looks a little too short to me. I will have to check the length on Monday but thanks for the link anyway
peter030371
| posted on 7/1/13 at 01:38 PM |
Checked the length on my car an its circa 900mm! I suspect that link is for the lower section only
Can't find one anywhere....can see me getting a custom one made soon which is starting to sound expensive just to get rid of a slight
'wobble' in the current shaft!
bigfoot4616
| posted on 7/1/13 at 06:45 PM |
i've the old column of my striker, i was once told it may be an escort one but i'm not sure really.
it had a quick release boss welded to it but thats been cut of now.
do you have any pics of an escort column so i can confirm if mine is?
