Author: Subject: Wanted Alloy fuel cap and neck...
SteveWallace
posted on 9/1/13 at 03:52 PM Reply With Quote
I'm after a lockable alloy fuel cap and neck for my Viento build but I'm trying to avoid paying ca £80 for a new one. Does anyone have a second hand one thats surplus to requirements that I could buy off them?
Also after some hose to connect the neck to the tank.
posted on 9/1/13 at 04:18 PM Reply With Quote
Waht about the ones boats use, tons to choose from and cheap.. wish I'd spotted them sooner!
Just google deck filler.
SteveWallace
posted on 9/1/13 at 04:37 PM Reply With Quote
Thanks for the tip. Would these be IVA compliant?
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 15/1/13 at 08:02 AM Reply With Quote
I bought mine from europaspares for £49.50
Linky
All I needed to do was string some picture frame wire to prevent the cap from being left behind at the petrol pump as this cap you can take the key out when it's not locked.
I looked around for months for this.
SteveWallace
posted on 15/1/13 at 10:16 AM Reply With Quote
Thanks - a good spot!
I'll give them a call to check to see if it has an integral unleaded restrictor (required for IVA) or whether I need to get one separately, which I would imagine is the case with most aero caps and necks.
theduck
posted on 15/1/13 at 12:20 PM Reply With Quote
I might be wrong but I don't think you need the restrictor anymore.
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 15/1/13 at 12:43 PM Reply With Quote
They do one as I have it. Think it was £10 or so??
SteveWallace
posted on 17/1/13 at 04:21 PM Reply With Quote
I phoned Europaspares and they said that you do not need a restrictor with that cap and neck to pass IVA.
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 17/1/13 at 04:32 PM Reply With Quote
For the same of £10 would you really want to risk it?
IVA = lottery
