theprisioner
| posted on 29/1/13 at 01:11 PM |
Loan/purchase/gift
I need a 5.5J x 15 wheel in any condition 108 4 hole pcd urgently. If in Edinburgh area I can collect. Otherwise I will pay postage + small amount.
mcerd1
| posted on 29/1/13 at 01:30 PM |
what offset & centre bore ?
might have a couple you could borrow
(although I suspect one is 6" wide)
[Edited on 29/1/2013 by mcerd1]
theprisioner
| posted on 29/1/13 at 01:34 PM |
34-35 mm offset, sorry!
theprisioner
| posted on 29/1/13 at 01:35 PM |
63mm Ford spiggot!
mcerd1
| posted on 29/1/13 at 02:34 PM |
I'll check the stock pile later, but with that offset I suspect they will be either 5x112 (granada) or 13"/14" (mk3 escort)
definatly have a pair of steels in 6x15" ET49 (i.e. early mk3 mondeo) with legal 195/60's on them - that any good to you ?
(I use them as spares for my mk1 focus - same size as its alloys )
or might have a 15" pug 206 wheel I could borrow, but that'll be a 65.1mm centre bore and I'm not sure about the width/offset....
theprisioner
| posted on 29/1/13 at 04:46 PM |
I have tried all the combinations of 6J and 7J the only wheel I can get (Minilite style) that has near enough the right offset and tyre combinatiion
is a 5.5 J x 15 with a 185/55/15 tyre if I cannot confirm that it fits or it does not fit in reality I will have to fit a modern wheel whhich will
look terible. So 5.5J or nothing....sorry!
theprisioner
| posted on 29/1/13 at 05:16 PM |
More information
More information
The problem is I want a Minilite design. The only company that makes a wheel like that is Compomotive with the larger offsets (38mm). They however are
not going to make any for a couple of months (maybe). Compomotive have some 5.5J x 15 ET34 in stock but I don't know if they fit with 185/55/15
tyres and give me sufficient margin.
14" Wheels do not fit with Hydra/VW/Passat OEM caliper. Iwould have to machine a lump off the caliper. The manufacturer does not recommend this
approach.
195/50/15 Tyres on a 6J or 7J wheel giving 0 margin with the GRP bodywork.
185/55/15 on 6Jx 15 ET34 are better but but would prefer just a bit more margin.
