unclechief
| posted on 11/3/13 at 02:22 PM |
good 2.0l pinto required
hi all,
i am after a good running 2.0l pinto as a direct replacement of my existing pinto lump. If you can assist please PM me with details.
Located in leicester but will travel.
regards
keith
Not Anumber
| posted on 11/3/13 at 04:03 PM |
I have what you are looking for.
My MK is currently running a very recently rebuilt standard 2.0 OHC Pinto engine. Only 2000 miles since a £ 1,000 rebuild which included:
new unleaded valve seats,
seals,
gaskets,
heavy duty oil pump
spray bar
cam followers
bores rehoned
piston rings
big and small ends
big end bolts
crank oil seals, oil filter
high pressure oil pump and sensor
heavy duty sump gasket.
I'm not entirely sure whether the crank was reground or just new bearings fitted.
The engine is in my MK and can be heard running. You are welcome to come down and try it in the car, the performance is good and it runs very smoothly
as one would expect for a recently rebuilt engine. I would need a small deposit before removing it from the car.
Chris
unclechief
| posted on 14/3/13 at 10:45 AM |
deal now done on an engine thanks for responses.
