r1_pete
| posted on 28/3/13 at 01:41 PM |
Wtd 52mm OD 3mm wall Alloy Tube
Is 52mm OD 3mm wall Aluminium tube a 'standard' size?
Does anyone have a metre or so spare / for sale?
Cheers.
Pete.
mcerd1
| posted on 28/3/13 at 02:00 PM |
between our suppliers (mainly aalco and richard austin) the nearest stock size is listed it as: 2" O/D = 50.8mm
with wall thinkness:
16SWG = 1.63mm
10SWG = 3.25mm
1/16" = 1.59mm
1/8" = 3.18mm
3/16" = 4.76mm
1/4" = 6.35mm
but aluminium is so easy to get extruded that others could be avalible as leftovers from big orders (~ 1 tonne min order)
[Edited on 28/3/2013 by mcerd1]
40inches
| posted on 28/3/13 at 03:12 PM |
Nearest I could find
2"x10g
Grimsdale
| posted on 28/3/13 at 03:52 PM |
i have a few pieces of 48mm OD, 5mm wall, about 450mm long if that's of any interest.
r1_pete
| posted on 28/3/13 at 04:33 PM |
Thanks Guys I guess its going to have to be 2".
austin man
| posted on 28/3/13 at 10:24 PM |
whats it for pete
r1_pete
| posted on 29/3/13 at 07:52 AM |
quote: Originally posted by austin man
whats it for pete
I'm having a second attempt at ITBs on the E Type using Triumph 955 bodies and an XJ6 EFI Manifold, I'm leaving the injectors in the XJ6
position, and the triumph bodies don't have an injector point, but, aren't re spacable, they are 52mm OD and using 52mm tube to mod the
manifold would have been ideal. I'll go with 2", I might actually try fitting a flat plate so I can use the standard triumph mounting
rubbers instead of silicone tube...
I'll post up some pics when I get started.
wilkingj
| posted on 29/3/13 at 10:19 AM |
What about a bit of Ally Scaffold Pole, thats about the right size and thick waller too.
Just my 2d's worth
Best Regards
Geoff
http://www.v8viento.co.uk
mcerd1
| posted on 2/4/13 at 03:53 PM |
alloy scaff bar is 1& 29/32" O/D with a 7swg wall (thats 48.4 x 4.47mm)
