Author: Subject: Help needed dcoe carb issues
carlknight1982
posted on 24/4/13 at 06:23 PM Reply With Quote
I'm looking for someone knowledgeable in dcoe carbs and their set up to come owner and help me with my carbs I have my mt booked for 04/05 and after having the carbs rebuilt i can't get the idle right or the throttle response, I don't ave the money to take to anywhere to get it sorted and have lost author in the guys who rebuilt. The carbs
I'm located in Flitwick Bedfordshire and home after 530 Eve's and all weekend
Logic will get you from a A to B
Imagination will take you everywhere.
r1_pete
posted on 24/4/13 at 06:35 PM Reply With Quote
Setting DCOEs up is not just adjusting the settings. Venturis, main jets, pilot jets, emulsion tubes all need to be matched to the needs of your engine. Additionally there are different DCOE bodies, with different numbers of progression holes to overcome acceleration flat spots particularly in 16v fours.
If you can list your engine, carb specs etc. people on here may be able to help, I have some experience of type 9s and 152s on 4 and 6 cyl engines.
carlknight1982
posted on 24/4/13 at 06:38 PM Reply With Quote
Carbs were running fine prior to the rebuild no major parts etc etc have been changed just what comes in the refurb kit
perksy
posted on 24/4/13 at 06:46 PM Reply With Quote
Dave Andrews's guide is pretty good.
http://www.s262612653.websitehome.co.uk/DVAndrews/webers.htm
There's no real 'black art' to setting them up as long as their not badly worn in the first place or have incorrect/mis-matched components.
carlknight1982
posted on 24/4/13 at 06:50 PM Reply With Quote
ive done that as much as i can without a carb balancer already hence the cry for help, but thank you anyway
perksy
posted on 24/4/13 at 06:57 PM Reply With Quote
You'll need to balance them properley otherwise they will never work i'm afraid
Some folks use a piece of tube but i've never had much success that way and have a proper carbalancer that makes it so much easier.
MikeR
posted on 24/4/13 at 07:11 PM Reply With Quote
you can balance at home with some plastic tube to your ear. sure I read a guide on here years ago.
carlknight1982
posted on 24/4/13 at 07:13 PM Reply With Quote
I don't know what I'm listening for, I'm just trying to get a little help on this one as I've tried all I know
posted on 24/4/13 at 07:26 PM Reply With Quote
You need to hold the tube in exactly the same position relative to each carb bellmouth, other than that it ain't rocket science DCOEs are the easiest carbs to balance by ear.
carlknight1982
posted on 24/4/13 at 07:29 PM Reply With Quote
Could being out of balance make them idle fast even when dole screws are screwed in all the way?
Dingz
posted on 24/4/13 at 07:57 PM Reply With Quote
Yes, because one set could be fully closed and the other open. As British Trident said try listening to them with a piece of tube, you are listening to the air being sucked into the carb they all have to sound the same.
went on and on.
