scutter
| posted on 25/4/13 at 06:13 AM |
Zetec thermostat housing
Folks I'm after a Zetec thermostat housing, I need one with 2 threaded temp sender holes in it. I currently have the circlip type housing.
Can anyone help?
Regards Dan.
AndyW
| posted on 25/4/13 at 07:10 AM |
I found 2 stat housings the other day in the garage, I will check the fittings and get back to you.
scutter
| posted on 25/4/13 at 07:37 AM |
Many thanks
bob
| posted on 25/4/13 at 08:27 AM |
Dan i will have a look when i get back from Dorset, i have the one with top sensor with small 1/8 npt bottom sensor for gauge kicking around in the
cave.
AndyW
| posted on 25/4/13 at 09:16 AM |
Sorry Dan, I do have 2 housings but the good one has the odd circlip type sensors and the other which has the standard screw in sensors is knackered
and has one of the pipes snapped off so u/s I'm affraid.
Good luck with the search..
stevebubs
| posted on 25/4/13 at 11:33 AM |
from memory, you need an old silvertop one..? I don't think they are particularly expensive new...
whitestu
| posted on 25/4/13 at 11:57 AM |
I drilled and tapped the top of my Blacktop plastic housing as it only had a hole on the bottom.
It's been like this for a couple of years with no leaks.
I have a couple more but not sure what type. I'll have a look at the weekend
Stu
ps I can't find those 2.0 cams anywhere! I think I may have binned them when we moved.
