peter bland
| posted on 2/5/13 at 06:18 PM |
gsxr lack of power problem, help
Looking for some help , my 1000 k2 has poor power through all gears, it starts up fine and runs ok but if i stop and turn the engine of and then back
on its back to normal and full power. I dont have any fault codes on the dash, have cleaned the fuel filter,im running a power comander, anybody have
any clues?
doobrychat
| posted on 2/5/13 at 06:53 PM |
fault codes via dealer mode? None..
exup valve in exhaust or has that been removed?
peter bland
| posted on 2/5/13 at 07:05 PM |
The exup valve is tie wrapped to the engine cradle, out of the way.
doobrychat
| posted on 2/5/13 at 07:15 PM |
I had an similar experience with with a later model.. turned out it was crank sensor after i change cam C11 and coil packs C24 +C27..
I also had no Code..
have you changed spark plugs lately? another part that fails without showing a code..
peter bland
| posted on 2/5/13 at 07:32 PM |
Changed plugs 6 months ago but I will check them again along with crank sensor , cheers
matt_gsxr
| posted on 2/5/13 at 08:15 PM |
fuel tank breather, probably not with EFI, but worth a thought.
peter bland
| posted on 2/5/13 at 08:29 PM |
Will check breather cheers. When I re start the engine it runs fine for hours, turning it of and back on seems to re-set it?
