<<  1    2  >>
Author: Subject: WTD Advice: Lathe Purchase
omega0684
posted on 15/5/13 at 04:33 PM Reply With Quote
Hi Guys,
I have been given the oppotunity to get "THIS LATHE" at 50% of the retail price, brand new.
Has anyone used this lathe and can voice an opinion on quality etc? Is it worth an investment and will be good for me to start learning to use a lathe properly.
All comments welcome
All the best
Alex
posted on 15/5/13 at 04:34 PM Reply With Quote
Crap.com
Get a Boxford or Harrison from a school or college mate..
Wadders
posted on 15/5/13 at 04:36 PM Reply With Quote
^ What he said...don't waste your brass.
something like this would be better
http://www.homeworkshop.org.uk/index.php?option=com_adsmanager&view=show_ad&adid=15317&catid=2
or even better this
boxford lathe | eBay
[Edited on 15/5/13 by Wadders]
franky
posted on 15/5/13 at 04:47 PM Reply With Quote
I'd go the other side and say its ok, really depends on what you want from it.
theprisioner
posted on 15/5/13 at 05:00 PM Reply With Quote
I would echo the previous post. I have a Myford Super 7 which is a small British made lathe the also did a ML10 which can be a good buy. I have heard good things about a Seig C8
http://www.mini-lathe.com/reviews/Lathes/Sieg_C8/C8.htm#Conclusion
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
big_wasa
posted on 15/5/13 at 05:19 PM Reply With Quote
It wouldn't be the worst buy of your life at half retail that is for sure.
If you want to make little bushes and things up it will do it, If you want to take a heavy cut out of a steel bar. They flex.
I've had the old English lathe and it was a fantastic bit of kit even at 90 years old but took up a quarter of the garage. I now have a little Chinese lathe and its fine for little bits in steel and bigger bits in alloy.
clanger
posted on 15/5/13 at 05:48 PM Reply With Quote
Noooooooooooo
lots of "what lathe shall I buy" info in search function....................knock yourself out !!!
richardm6994
Pile of rubbish. I worked at a place which had one and it was the worse machine I have ever worked on!!!
I know it's half price, but its still not worth it. I've got a myford super 7 and a Colcheter student for around £700 each and they are two of the best manual lathes around.
[Edited on 15/5/13 by richardm6994]
rf900rush
posted on 15/5/13 at 07:22 PM Reply With Quote
I have a Warco version without the Milling bit.
Had no problems using it for most of my requirements.
Even converted it to CNC to make some 50mm by 0.5mm pitch threads.
Mine only cost me £100 so still worth it.
But I now have a basic Denford Viceroy. Looks much better but needs more room.
£500 pound still may be spent better.
It may help if you describe you needs for one for.
We don't all need a £200 makita drill to put a couple of shelves up one in a while.
[Edited on 15/5/13 by rf900rush]
omega0684
posted on 15/5/13 at 07:42 PM Reply With Quote
ok guys thanks for the advice, to answer a few questions, i would mainly be working with ali, pulleys, spacers, adapters etc, i have no need to be maching big steel pole, but as my skill develops i would like to learn more,
So the general consesus is a no, i'll keep looking for the time being. thanks for the links to other sites, if anyone else has any other info on people selling or see lathes for sale then please drop me a u2u.
if you could post up links to more sites that would be great
paulf
posted on 15/5/13 at 08:13 PM Reply With Quote
I would say that it is probably ok for light work if it only costs you £500, a decent older English lathe such as a myford boxford or Harrison would cost at least as much without the drilling attachment although that is of limited use mounted on the lathe as it is. If you only need to do light work then I would consider it but if you intend doing heavier work or close tolerance work at a latter date then look for an older heavier duty lathe with plenty of accessories, but you will have to pay more unless it is a large difficult to move machine.
Paul
franky
posted on 15/5/13 at 08:59 PM Reply With Quote
I'd go as far to say all the myfords are well over priced for what they are, because they're small it makes them expensive. That clarke would be fine for what you want, you'll always get your money back.
I recently sold a Sieg m4 for £1350 just because they're small and single phase, I then bought this....
BOXFORD STS 250 LATHE WITH INDUCTION HARDENED BEDWAYS | eBay
as it finished at rush hour drive home time and is 3 phase it was a bit of a bargain, its a bit of a joke that it was £350 less! Have you thought of a 3 phase machine to run off a converter?
Talon Motorsport
posted on 16/5/13 at 07:24 AM Reply With Quote
You don't need a power convertor to run a 415v - 3 phase motor, for 1/3 of the money you can just buy a 240v - single phase motor. Most things are either flat or V belt drive you just need the right pulley for the motor.
mark chandler
posted on 16/5/13 at 07:34 AM Reply With Quote
Or make up the third phase with a 50uf capacitor, you lose a bit of power but for home work going slowly is not such a bad thing.
trextr7monkey
posted on 16/5/13 at 07:57 AM Reply With Quote
We have 3 lathes here and bought one of those a while back to run a 4 jaw chuck on permanently- mostly used by kids making square ended knobs/ handles etc in brass it is Ok ,not as good as more expensive machines but does the job. Slightly off topic it did not come with a micro switch on chuck guard so we had that retro fitted
We still have a Denford Viceroy sitting in the corner awaiting a new loving owner - currently fitted with 3 phase motor and all wiring was renewed a while back if no body buys it I might take it home when I retire in about 5 years!
It needs a chuck and the work lamp sorting if you are fussy but comes with4 way tool post ,tail stock etc £350 takes it - there's an ad on here somewhere if you search
Also have just removed a Startrite Inca planer, 3 phase, solid cast iron jobbie will run all day for years to come, not getting any use here prob about £150 which is a fraction of what we paid to Mr Dewalt for a more compact replacement!
atb
Mike
owelly
posted on 16/5/13 at 08:30 AM Reply With Quote
Buy Kippers lathe. Job done.
http://www.ppcmag.co.uk
dave_424
posted on 16/5/13 at 08:49 AM Reply With Quote
I managed to pick up a Colchester Chipmaster lathe off ebay from someone local for under £400, single phase as well. It has done everything I want it to do so far but would like a larger machine like most people.
Definitely hold out for some old heavy english iron if you don't need it right away, I see plenty of older machines pass by that are either being sold by the wife or son of an old chap who has passed away, or someone who no longer needs it and needs the space.
mcerd1
posted on 16/5/13 at 08:57 AM Reply With Quote
keep looking Alex, we got a version of an old Hembrug A1 for £500
Alfa145
posted on 16/5/13 at 09:16 AM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=181655
richardm6994
posted on 16/5/13 at 10:40 AM Reply With Quote
Thats exactly what I did with my colchester student. Worked a treat
franky
posted on 16/5/13 at 11:52 AM Reply With Quote
It makes life simpler when there's built in suds pumps or other feeds etc, then the cost balances out.
I've got one to run an old Bridgeport with a duel speed head, the converter runs both, also having it means you can buy other 3 phase stuff cheaply which quickly pays for it.
omega0684
posted on 16/5/13 at 08:12 PM Reply With Quote
thanks for all the advice guys!
I have spoken to Kipper this evening and agreed to purchase his, really nice guy!
I think i have invested in a very nice piece of kit!
Thanks again guys LCB to the rescue!
mcerd1
posted on 17/5/13 at 10:02 AM Reply With Quote
I don't think you'll be disappointed - they're neat little bits of kit
[Edited on 17/5/2013 by mcerd1]
kipper
posted on 18/5/13 at 10:20 AM Reply With Quote
Re lathe
Just a note to thank you guys for pointing Alex in my direction.
The lathe is now palletised and awaiting collection.
Denis.
Where did that go?
Wadders
posted on 18/5/13 at 10:35 AM Reply With Quote
Good choice, if you decide to upgrade to a bigger machine
in a couple of years you will get your money back.
Can i recommend you buy 'the amateurs lathe ' by H A Sparey
Great little book full of useful stuff .
Have fun with your new toy.
Atb
Al
<<  1    2  >>
