Author: Subject: Wanted 15"ford PCB alloys
mazie
posted on 26/7/13 at 08:06 AM Reply With Quote
13"s do not fit the fury well so I'm looking for a set of 15x7 108pcd alloys, tyres not needed as ill be fitting 888's unless anyone has a set with decent rubber on.
The set of laser wheels and slicks for sale of part ex?
daniel mason
posted on 26/7/13 at 08:28 AM Reply With Quote
13'" rims should fit the fury perfectly well. compomotive cxr's look nice. offset is the key.
i think mine ran 13" x 6" rims 185/60 and 205/60 tyres et 18 front et6 rear
omega0684
posted on 26/7/13 at 10:20 AM Reply With Quote
i have a set of TSW Blades for sale,
http://www.locostbuilders.co.uk/viewthread.php?tid=183401
open to a sensible offer, and im in coventry too!
big_wasa
posted on 26/7/13 at 11:19 AM Reply With Quote
Don't forget the offset. If you have laser rims you will be looking for rims with an offset of around et18. That's peugeot dims. Most Ford rims you come across will be around et38.
mazie
posted on 26/7/13 at 11:59 AM Reply With Quote
I've been looking at the diameter of 60 profile tyres on a 185x13 and it's almost 30mm smaller than the current 195 50 15's , I could lower the rideheight slightly to get them to fill the arches but I'd rather not change it all around between the everyday road tyres and trackday rubber. I'd wanted to run slicks as I can get them for between 5 and 10 pounds each, compared to £80 for a 13" 888. Ill add a pic of what they are like fitted on the car.
mazie
posted on 26/7/13 at 12:12 PM Reply With Quote
daniel mason
posted on 26/7/13 at 12:26 PM Reply With Quote
are you not adjusting suspension setup when you move to 15" wheels anyway?
id get it set up right for the 13" wheels and look for a second hand set of 13's for track use.
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 26/7/13 at 03:45 PM Reply With Quote
I have a set of brand new pro race 1.2's 7 x 15 PCD 108 in gloss black for £425 delivered
