Author: Subject: Rear Sierra Calipers... or better alternatives...
yellowcab
posted on 3/10/13 at 05:22 PM Reply With Quote
Noticed my OSR caliper is leaking, but not from the flexi hose... they've seen better days to be honest...
Anyone got any direct replacements, or better alternatives?
Dave Bailey
posted on 3/10/13 at 07:03 PM Reply With Quote
I have the hispec ones that Westfield use.. Achieved 28% on hand brake test so unlike the wilwoods the handbrake works...
Dave B
Ben_Copeland
posted on 3/10/13 at 07:05 PM Reply With Quote
Alloy Vw ones. Direct bolt on BUT only fit under 15s
Ben
Locost Map on Google Maps
Enter Your Details Here
austin man
posted on 3/10/13 at 09:48 PM Reply With Quote
I reckon the focus ones are worth a look and try the slider appears to be the same as the sierra one
posted on 3/10/13 at 09:52 PM Reply With Quote
Keep in mind VW callipers are smaller bore giving less rear braking force.
yellowcab
posted on 3/10/13 at 10:50 PM Reply With Quote
I wouldn't really mind direct Sierra replacements for the time being
Ben_Copeland
posted on 4/10/13 at 06:15 AM Reply With Quote
But they sit on a bigger disc so probably not much in it. They produce enough force to stop my car on their own which well, as I found out when my front m/c failed while driving!
They also are much much lighter.
Ben
mcerd1
posted on 4/10/13 at 07:28 AM Reply With Quote
how about sorting the caliper yourself ?
bigg red sell the seal kit for £22 (and pistons, slide pins etc if needed) - the old sierra haynes manual tells you how to strip and rebuild them...
posted on 4/10/13 at 09:10 AM Reply With Quote
But if you need guide pins and a piston it works out cheaper to buy a exchange calliper.
