Mikef
| posted on 14/10/13 at 11:48 AM |
balancing pistons
Have some new pistons, for winter project. They have no balancing pad on the underside of the crown. Any body any suggestions as to where to remove
the metal from without weakening the crown or the pistons. There is 4g difference. They are K series 160 pistons.
HowardB
| posted on 14/10/13 at 02:04 PM |
I have just had some work done by specialist engines,.. Ian is a very knowledgeable man,.
T: 01375 378 606
F: 01375 381 249
15 Curzon Drive
Grays
Essex
RM17 6BG
hth
Howard
snapper
| posted on 14/10/13 at 03:28 PM |
You want to balance rods end to end as well as total weight this can be done by removing weight from either end then weigh piston pin and rod you can
remove weight from inside the gudgeon pin to balance pistons
4 grams is not a lot as pistons and rods can be over 500
I eat to survive
I drink to forget
Mikef
| posted on 14/10/13 at 04:11 PM |
Thanks for this, I was going to do the rods as well , but had never thought about taking out of the gudgeon pins. I know its not a lot , but it all
counts and I have the time.
MF
ashg
| posted on 15/10/13 at 03:25 AM |
Is it a race car? If not don't bother.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
