Author: Subject: Want- motor v pulley for 5/8 inch dia shaft
trextr7monkey
posted on 17/10/13 at 10:39 AM Reply With Quote
Hi as above, have found a motor to convert a 3 phase lathe to single phase
need a pulley something like the above to fit the motor, it has a 5/8 inch diameter shaft, 3/16 key way with 1 1/2 inches of shaft protruding beyond the motor bearing case.
I suspect something from an old pillar drill might suit but we haven't any knackered ones lying about
Mike
907
posted on 17/10/13 at 04:49 PM Reply With Quote
When I motorised a set of slip rolls I used Taper Lock fittings. ( eBay, or engineering supplier )
You buy the centre to fit the shaft and the outer to fit whatever you need, in your case, a pulley of a suitable size.
HTH
Paul G
trextr7monkey
posted on 18/10/13 at 12:01 PM Reply With Quote
Cheers, thought I'd see if my luck was in first, before pursuing other routes
We have a few other lathes and a trained turner here s he could prob rustle something up but he's away at moment
atb
mike
907
posted on 18/10/13 at 01:21 PM Reply With Quote
Sorry. I obviously misunderstood your original post.
Please accept my apologies.
Paul G
trextr7monkey
posted on 18/10/13 at 04:47 PM Reply With Quote
Hi Paul , on the contary thanks for responding as there wasn't loads of detailin my post and no one on here has psychic powers !!
We are hoping to sell the machine in question so if we can sort up a. Pulley it is less of a project for someone taking it0on atb
Mike
