r1_pete
| posted on 6/11/13 at 11:40 AM |
Wtd 1 x 3.2mm 1/8" Gas welding Rod
An odd request, but has anyone in the Sheffield / Chesterfield area got a 1/8inch, 3.2mm gas welding rod I can scrounge for a pint or so.
I needed to alter my e type wing, and unrolled the wired edge, but now need an eigth inch rod to re finish it, I can't re use what was there as
it is thicker, I unrolled the edge to lengthen it and correct the panel gap, so the resulting roll is smaller.
I've got plenty of 1/16 and 3/32 rods but no 1/8s
Cheers.
Pete.
NigeEss
| posted on 6/11/13 at 11:47 PM |
I've some 1/8" brazing rods, not local but more than happy to post you a length.
| posted on 7/11/13 at 10:01 AM |
Coat hanger from the dry cleaners might do it.
redturner
| posted on 7/11/13 at 02:22 PM |
I have used galvanized fencing wire before, worked a treat.....
