chicade
| posted on 29/12/13 at 09:16 PM |
Wanted yoko A048r soft 205/60/13
Wanted yoko A048r soft 205/60/13 two of if possible? What have you got? Must be in good condition as wanted for road use
aerodynamix
| posted on 30/12/13 at 04:58 PM |
I have one 203/60r13 Yoko Soft loads of tread, however it appears to be reasonably old , I do have another but have a vague idea that the bead may be
damaged although is on top of the racking as is not easily accessible , will try and look later to check .
I am in Gloucestershire , can package if needed , the good tyre must be worth £25 as has at least 5-6mm of tread .
u2u or call 07971 264550
I also have 2 x 185/60x13 but they only have about 3mm
Edited to add all tyres are yoko a032r , three are good other has damaged bead
[Edited on 30/12/13 by aerodynamix]
chicade
| posted on 5/1/14 at 09:37 AM |
Still wanted 2 x 205 60 13 Yokohama a048r soft tyres must have good tread as wanted for road use what you got guys??
chicade
| posted on 8/1/14 at 12:19 PM |
Bump? Anyone got any??
