joni
| posted on 24/1/14 at 09:31 PM |
Wanted westfield bonnet narrow car
Hi all iam looking a westfield bonnet Let me no what you have thanks jonny
[Edited on 25/1/14 by joni]
perksy
| posted on 24/1/14 at 10:12 PM |
Would that be for a wide or narrow bodied Westfield ?
Also what engine are you using ? (possibleissue with cutout for carb/TB's air filter)
joni
| posted on 24/1/14 at 10:55 PM |
Is there a difference in the wide and narrow body as I no the the nose cones are the same one with no holes would be good but not that important
Smokey mow
| posted on 25/1/14 at 08:46 AM |
There are 4 different types of Westfield bonnet, two for the wide-body and two for the narrow. None of these are easily interchangeable with the
other.
Narrow bodywork is roughly 3" narrower than the wide body where it meets the scuttle. The two styles of narrow are referred to as high line and
low line due to the 1.5" difference in it's height where the bonnet meets the nose cone.
The two style of wide bodywork were the "kit" wide and the current ZK wide bodywork. The kit wide nosecone is very similar to the high
line narrow nose but they are not quite the same. The bonnet and nose will fit together ok but the swage line down the side is at a slightly
different height.
See the link below for more detail and pictures.
http://forum.wscc.co.uk/forum/index.php/topic/104285-spot-the-difference-–-bodywork/?p=1084251
joni
| posted on 25/1/14 at 01:42 PM |
It's a narrow one
Hi it's a narrow bonnet I need thanks for the help
Smokey mow
| posted on 25/1/14 at 06:15 PM |
I still have this available
http://forum.wscc.co.uk/forum/index.php/topic/102903-new-narrow-body-bonnet-chrome-yellow/?p=1066746
£200 collection only from Colchester, Essex
joni
| posted on 25/1/14 at 06:26 PM |
Ha smokey I just sent you an email 2min ago seen it on the westfield site
