INDY BIRD
| posted on 10/10/14 at 09:07 AM |
Wanted -10 fittings for oil lines and braidd hose
Hi all
I am after 2x -10 (m22x1.5) Ali fittings straights would be ideal but 90deg may get away with,
For oil cooler
If you have any braided oil line to fit also required,
Checking here before I buy new,
Thanks for your help as always
Sean
rodgling
| posted on 10/10/14 at 09:21 AM |
I have about 1 - 1.5m of -10 braided hose if that's any use? I will check length and get back to you.
INDY BIRD
| posted on 10/10/14 at 09:37 AM |
That would be perfect if you have it as I need around that length cheers
Sean
adithorp
| posted on 10/10/14 at 11:40 AM |
If you have to buy the fittings, I can recommend
JJC's APS
range
Usually on the ball with delivery (standard postage usually arrives next day) and the price/quality are good as well.
[Edited on 10/10/14 by adithorp]
http://jpsc.org.uk/forum/
daniel mason
| posted on 10/10/14 at 06:01 PM |
I've got a load of jic fittings (red and blue ) but not sure what sizes they are. Also sections of braided hose. If you let me know what you
Need I'll let you know what I have
