<<  1    2  >>
Author: Subject: Westfield SEiW Zetec Off Side Engine Mount...URGENT...PLEASE!
lordbenny
posted on 29/6/15 at 04:41 PM Reply With Quote
Mine snapped today,I'm have a road trip planned with my daughter who is over from Australia for just two weeks. Westfield have none in stock and have a two week make/powdercoat and delivery date on a replacement.
PM or Call me on 07976 929843 if you can help.
owelly
posted on 29/6/15 at 04:46 PM Reply With Quote
Are they not just standard type engine mount bobbins? Like the Landrover type ones? Any half decent motor factors will have something similar on the shelf.
http://www.ppcmag.co.uk
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 29/6/15 at 05:07 PM Reply With Quote
If it was anything like mine it was the metal part of the mount that cracked and nearly snapped. Can you not get it welded up and braced ?
lordbenny
posted on 29/6/15 at 05:23 PM Reply With Quote
This is what it looks like....can it be welded?
ian locostzx9rc2
posted on 29/6/15 at 05:32 PM Reply With Quote
Could be welded up looks a pretty poor design might be worth checking the one on the other side aswell
femster87
posted on 29/6/15 at 05:35 PM Reply With Quote
Yes it can, where in the country are you? If your are close to me I can suggest a decent fabricator who would do it while you wait
dilley
posted on 29/6/15 at 05:42 PM Reply With Quote
I'm in Cambridgeshire, I'll reweld for you....
lordbenny
posted on 29/6/15 at 06:19 PM Reply With Quote
Sutton, Surrey, SW London. I'll try a local place tomorrow.....will the weld be strong enough?
Mark100
posted on 29/6/15 at 06:20 PM Reply With Quote
serch ebay for
CASARVA-LOCOST-KIT-CAR-ZETEC-ENGINE-MOUNTS-ALL-ENGINES
not my ebay ( ive just nicked the picks and details ) but ive got a set going spare if there any good to you
gremlin1234
posted on 29/6/15 at 06:40 PM Reply With Quote
you can see the original weld was stronger than the nearby material.
edit, and brace it a bit if you can.
[Edited on 29/6/15 by gremlin1234]
HowardB
posted on 30/6/15 at 05:52 AM Reply With Quote
where about's in the world is the original OP?
Howard
lordbenny
posted on 30/6/15 at 07:30 AM Reply With Quote
I dont understand!
posted on 30/6/15 at 07:40 AM Reply With Quote
AdamR20
posted on 30/6/15 at 08:19 AM Reply With Quote
Done correctly, it will be stronger than the original. I had the same issue with mine and it's still going strong a few years after I tweaked it
HowardB
posted on 30/6/15 at 08:25 AM Reply With Quote
I dont understand!
Ooops I missed that one,. too far from me,.
As per previous, a good weld will be more than good enough, and any concerns get an additional brace added.
good luck
Howard
lordbenny
posted on 30/6/15 at 08:34 AM Reply With Quote
Found a welding place 1 mile from my house!!!
http://www.specialistweldingservice.co.uk/contact/
He's quoted £60 to fabricate a new base plate in 6mm steel (current one is 5mm) use the old plate as a template and weld it all up. About the same price as a new one from Westfield and it will be done in a couple of days. Can't complain about that!
ragindave
posted on 30/6/15 at 09:24 AM Reply With Quote
One was forsale on the Westfield forum.
http://forum.wscc.co.uk/forum/index.php/topic/113994-zetec-engine-mount-os/
[Edited on 30/6/15 by ragindave]
lordbenny
posted on 30/6/15 at 09:29 AM Reply With Quote
I think that's for a black top zetec and not a silver top one. It's not the same as mine.
kingster996
posted on 30/6/15 at 09:30 AM Reply With Quote
Note - although that looks different, it will fit - it's the newer version that sits to the left of where your current one will have gone to allow it to fit Blacktops (oil filter position). I have one of them on my Silvertop.
You can just see it here:
[Edited on 30/6/15 by kingster996]
I used to be indecisive, but now I'm not so sure
lordbenny
posted on 30/6/15 at 10:04 AM Reply With Quote
Well, you learn something new every day! As I said, my local welder is fixing mine so I think I'm sorted. Thanks for all your invaluable replaces though guys. X
lordbenny
posted on 30/6/15 at 07:48 PM Reply With Quote
Funny that when I asked Westfield themselves if it would fit I got this reply....
Hi Andy
No unfortunately they are different.
Kind regards Mark
Mark Walker
Technical / Engineering Manager
Potenza Sportscars Limited
kingster996
posted on 30/6/15 at 09:03 PM Reply With Quote
Hi Andy
Kind regards Mark
Mark Walker
Better remove my engine then
lordbenny
posted on 7/7/15 at 03:25 PM Reply With Quote
Sorted with an extra 1mm thickness on the plate. Courtesy of SWS http://www.specialistweldingservice.co.uk/contact/
perksy
posted on 7/7/15 at 08:25 PM Reply With Quote
Not the first one of these that has failed and they are worth checking whenever you do a nut n bolt check of your westfield
kingster996
posted on 8/7/15 at 10:52 AM Reply With Quote
Looks like oil pressure sender cut out is missing? I assume you have relocated it?
<<  1    2  >>
