jtskips
| posted on 9/3/16 at 09:11 AM |
duratec double valve springs
As above wanted thanx john
| posted on 9/3/16 at 05:31 PM |
Can't help you, but I am interested to know what you are doing to need them?
jtskips
| posted on 9/3/16 at 07:08 PM |
well at the moment the 2.0 duratec that i have has 11.2 mm lift kent cams fitted , that you can use with single uprated springs and pistons with valve
pockets in , but i also have a 2.3 duratec engine that i am in the process of putting 13.3 mm ultimate race cams in, that should need double valve
springs , i have been advised if the engine is under 280bhp single springs will be ok , i have checked the crush height on the uprated spring that i
have and they dont go low enough for the new cams , the engine will be under 280bhp , just out to see if any one on hear has
some adequate springs laying around ,single ones will do if they go down to 22.27mm crush hight thanx john
[Edited on 9/3/16 by jtskips]
| posted on 10/3/16 at 11:05 AM |
Ah OK - understand the need now.
Hope you get what you need.
