Chris_G
| posted on 13/10/05 at 11:39 PM |
Zetec Pulleys x 2
I need 2 pulleys for my Zetec:
1) The large multi-v puley on the end of the crank that drives the alternator and water pump.
2) The multi-v water pump pulley that is driven by 1)!
Chris
Donners90
| posted on 14/10/05 at 07:05 AM |
If you can't find sencond hand ones..
Ford part numbers are
Crank Pulley (pre 1998) - 928M-6B320-DB (FINIS # 6599021) = £53.70
Crank pulley (post 1998) - 928M-6B320-DD (FINIS # 1038330) = £55.59
Water pump pulley 93BB-8509-AA (FINIS # 6911490) = £13.10
Hope this helps
James
Mix
| posted on 14/10/05 at 07:39 AM |
Water pump pulley takes 5 minutes to remove from a Zetec engined Escort, unfortunately the same can't be said for the crankshaft pulley
Mick
