Avoneer
| posted on 8/3/06 at 09:03 PM |
Small Screwdriver Bit Adaptor Thing
One that you stick your hex sized screwdriver / torx bits in at one end and the other end has a square hole for a ratchet spanner.
Anyone got a spare one?
Commonly found on the top of cheap multi bit/handle kits.
Pat...
| posted on 8/3/06 at 10:09 PM |
by square hole, do you mean like a 1/4 inch one for a wrench? Ive seen one recently, but then, my tools dont last long
The bit itself is just under 7mm IIRC, and can be stuck straight into a 7mm socket provided you dont need to twist too hard.
Avoneer
| posted on 8/3/06 at 10:32 PM |
Yep, that's the one.
Tried the 7mm idea, but not strong enough.
Someone must have a spare they probably got in a cracker or something.
Pat...
Avoneer
| posted on 8/3/06 at 10:33 PM |
Pat...
| posted on 8/3/06 at 10:35 PM |
what you trying to undo? I once got a bleed nipple off by welding a 3' bar onto it, and still managed to reuse the nipple afterwards!
overkill or what.
My lil' cutoff tool is perfect for notching a worn head so it can be undone with a flat driver.
I assume you've already tried it in a cordless?
Avoneer
| posted on 8/3/06 at 11:03 PM |
I got them out eventually with mole grips and the tiny bit.
I used to have one of these adaptor thingies, but have misplaced the bugger as I used my small bits on my ratchet all the time.
Pat...
stevebubs
| posted on 9/3/06 at 02:58 AM |
Pat...
You should be able to use an imperial socket - think it's about 1/4in.
rusty
| posted on 9/3/06 at 08:39 AM |
Yes thats right they are 1/4" but the only draw back with using a 1/4" socket is that thye will not have the magnet or spring clip that
the proper bit holders have so the bits keep dropping out.
| posted on 9/3/06 at 06:20 PM |
It's possible to get ratchets with a built in 1/4 A.F. magnetic socket , very similar in size as a 1/4 drive ratchet . VERY useful tool
Avoneer
| posted on 9/3/06 at 08:32 PM |
This is the bugger:
1/4" square to 1/4" hex.
Anyone know where I can buy a cheap and cheerful one?
Only websites I can find want £3 - £5 pound postage.
Pat...
Avoneer
Ooooppp, forgot the pic:
