Paul (Notts)
| posted on 29/8/06 at 02:27 PM |
rocker x2 for RV8
Spent the last 3 hours trying to set the tappet pre load only to discover I need two replacement rockers one on each shaft ( cant afford new rocker
shaft kit ) –
Any one with a couple going spare –
Pay postage + pint or collect at Donnington
Paul..
Agriv8
| posted on 29/8/06 at 02:56 PM |
I have 16 from a seized engine ,
Not sure how good they are, will have a look tonight if I am allowed in the garage.
Oh do you need bend to the left or bend to the right when veiwed from above ?
Can post them off tomorrow if Required
When is donnington ?
Regards
Agriv8
[Edited on 29/8/06 by Agriv8]
| posted on 29/8/06 at 03:00 PM |
shaft kit ) –
you realise the rockers are handed? well, if they are oem they will be; they will be aluminiujm alloy with hardened seat that pushes the tappet
offset depending on the valve.
the aftermarket ones are universal and nasty cast iron stuff.
rimmer bros. sell the oem; craddocks & paddocks (LR spares, sell the after market ones cheaply; I bought the last alloy ones from craddocks but
can't remember whcih handed ones - they had too few of one but many of the other - worth calling them to see if they still have them.
again the same people cra/pad-docks for shafts;
How badly worn are yours? I have a pair I removed in reasoable nick - will get the micrometer on them to see conditon - yours if you're
interested for price of postage.
the rockers where on the hardened seat - if you have oem - it sould be possible to press out the seat and fit another or build it up and then case
harden it - probably more hassle than it is worth.
Paul (Notts)
| posted on 29/8/06 at 03:13 PM |
Cheers Agriv8,
The valve is offset to the right hand side compared to the push rod when looking from the valve side.
u2u me money details and Ill u2u address
thanks for the help 02GF74
froggy
| posted on 29/8/06 at 03:21 PM |
paul i hyave a good set with brand new shafts going spare if you want them done a few hundred miles ,cover the postage and you can have them
wilkingj
| posted on 29/8/06 at 03:22 PM |
1st check the shafts they usually wear on the underside. If they are scored they scrap them.
The filings from the scoring get embedded in the ally rockers and grind away the shafts. What happens next is those filings get into the oil and then
attack the big ends and mains. If they are knackered, its not worth replacing with more worn bits.
Especially if you have just fitted a new cam and crank bearings etc. I suppose it depends on what you have paid out on the engine. £200 and its not a
big deal. £2K is another matter.
Best Regards
Geoff
http://www.v8viento.co.uk
Paul (Notts)
| posted on 29/8/06 at 03:48 PM |
Froggy,
Yes please.................................................
I will u2u my address...
will cover postage and a couple of pints
Paul
froggy
| posted on 29/8/06 at 03:49 PM |
no prob mate dont suppose anyone has a spare efi unit to go with my latest purchase?
Agriv8
| posted on 29/8/06 at 08:59 PM |
froggy,
Now either those are small bricks on your wall or thats one LARGE Turbo.
tell me that not going in the kitten !!
Turbo lag possibly an issue I think you need to take some more of those 'Special pills ' or I have a freind who specialise in those
rubber pants for poeple who have no control over there bowels. may be a safe option for the first wet roudabout and that turbo spinning up.
Mad Mad Mad.
PS U2u sent regarding EFI unit
Regards
Iain
wilkingj
| posted on 29/8/06 at 09:22 PM |
Froggy... When you get it alll fitted and working... Can you make a recording of the Swissssshhhh and PUfffffff sounds so I can play them over a loud
speaker on my Viento
Best Regards
Geoff
wilkingj
Best Regards
Geoff
wilkingj
| posted on 29/8/06 at 09:24 PM |
Best Regards
Geoff
wilkingj
Best Regards
Geoff
wilkingj
Best Regards
Geoff
