scoop
| posted on 17/8/07 at 09:28 PM |
7 PIN PINTO AMP/IGNITION MODULE
I was kindly donated one by Benzine but its the wrong one (only 6 pins/wires) so in need of a seven pin/wire one please.
scoop
| posted on 21/8/07 at 12:18 AM |
I take these do exist do they or am i imagining it
bob
| posted on 21/8/07 at 10:23 AM |
Hi scoop
The one i used on my old pinto set up had 6 pins but i only used 5 of them, maybe worth checking the wiring.
Not sure if this is the type you are looking for but i know this is one of the two variations i've seen used.Image deleted by owner
bob
| posted on 21/8/07 at 10:24 AM |
the unit
scoop
| posted on 21/8/07 at 11:51 AM |
Got one of those mate. Im fast concluding that i need a different plug and dizzy.
Cheers mate
bob
| posted on 21/8/07 at 02:35 PM |
Or you need this set up from darren which will get the pinto SOHC running using the diagram above.
link
scoop
| posted on 21/8/07 at 05:44 PM |
I am speaking with Darren as it happens on my other thread about this problem.
Ta
