James
| posted on 5/1/04 at 04:42 PM |
*WANTED* Pinto Fuel pump drive mechanism.
http://www.locostbuilders.co.uk/viewthread.php?tid=9668
Anybody whose broken a non EFI Pinto got a spare drive 'pin/rod' and mechanism to drive the mechanical fuel pump from the cam on the
timing shaft to the pump?
I'm converting my EFI 2.0 to run off carbs and want to use a mechanical pump. I've got the pump but not the drive pin for it!
I'm not sure if it needs to be a 2.0 tho.
Thanks,
James
Mk-Ninja
| posted on 5/1/04 at 08:14 PM |
See reply in E&T
I'm sure I've got one, just don't know where I've put it
James
| posted on 6/1/04 at 03:06 PM |
I've u2u'd you!
James
Mk-Ninja
| posted on 6/1/04 at 03:33 PM |
You have reply
