Ford Type 3 Gearbox and related bits-n-bobs for sale.
Has really good close ratios, has a much better 1st gear ratio than the type 9 I've just fitted. Lighter than a type 9 too.
was half
thinking about putting it back in - but know never to take a step backwards
I will try to look-up / measure the ratios if anybody is interested.
I have no history for it other than it was fitted to my 1989 westfield when I bought it last year. Previous owner said he had seen some problems with
down-shift into 2nd. Not sure I ever did, but may be I didn't drive it hard enough or long enough to see them. Other than that, seems OK, smooth
to turn.
Seen them advertised for silly money on flea-bay Ford 4 Speed type 3 Gear Box and Bellhousing on eBay (end time 11-Nov-10 12:07:59
GMT) but don't expect to get that much - Make me an offer ?
Type 3
Burton Link
Matching iron Bell housing. Was Fitted to Zetec black top, so "standard" Ford pattern.
- £10
Matching Propshaft.
7/8" x 20 spline for gearbox and output for old Ford Escort diff. UJs all smooth turning.
£50
Propshaft
Prop End
Prop end
Helix Motorsport Clutch
215mm diameter, friction material 7.5mm (compresses to 7.2mm when you squeeze the springy inner plates together)
Only done a few 100 miles (as far as I know)
(I got an identical one but with splines for type 9 gearbox and that cost about £85)
£40
This was all removed from my Westfield when we "upgraded" to a Type-9 gearbox this summer.
Prefer collection from Hinckley( between Leicester / Coventry , near to Mallory Park). Or will try to help deliver/meet if it helps. Have friends in
Oxford, York and Letchworth if that helps.
All prices open to negotiation.
cheers
Tim.
tim at ellershaw dot com
[Edited on 18/10/2010 by TimEllershaw]
Sorry, I guess I didn't write the advert very well:
The clutch plate for sale is a 20 spline x 7/8th inch input to suite the Type 3 gearbox.
I believe it is this :
Performance Clutches
The one I am selling will not fit a type 9 gearbox. I only mentioned the type 9 clutch to give an indication of price new.
Tim.
Hi Tim,
Is the clutch still available?
Ben
Hey Tim
Would you be willing to ship the Bell to Canada?
Thanks, Ted
Originally posted by andkilde
Hey Tim
Thanks, Ted
Hey Tim, I think I may be having a brain fade -- the transmission mounting face is similar to a type 9, not a T5 as I'd originally thought.
Sorry Ted
hi mate could be really interested in the prop
just gota check it will fit my box
how much all in?
thanks
??? anything?
