Fuel filler on ebay.
Bought one. To make SVA compliant fit a suitably sized washer/plug into filler pipe to prevent anything other than unleaded being used.
Linky
How much are you looking fot the lockable fuel filler posted to Greece?
Regards
Alex
Linky
The filler restrictor is a requirement if the vehicle is fitted with a catalytic converter.
Might not need one, the green bit and that it comes from Italy may mean it's unleaded only anyway.
Since you can't actually buy leaded anymore it amazes me that the manufacturers don't update their aerocap/monza designs. They could use
all the old stock for diesel kitcars
[Edited on 14/3/08 by iank]
Since you can't actually buy unleaded anymore it amazes me that the manufacturers don't update their aerocap/monza designs. They could use all the old stock for diesel kitcars![]()
(although I have fitted a restrictor anyway)
Erm, yes, bugger. Edited to fix.
