madmandegge
| posted on 23/10/08 at 10:19 AM |
Locost dials/gauges - 60mm
Not entirely sure if any of you guys will be happy with the quality of these, I have ordered stuff off dealextreme before, items are usually of quite
good quality, and of course free postage
They have tachometer/boost/oil temp/oil pressure/voltage and vacuum.
http://www.dealextreme.com/products.dx/category.708~search.60mm
They work out at £12-13 posted with the current conversion rate
[Edited on 23/10/08 by madmandegge]
posted on 23/10/08 at 10:48 AM |
it's quite hard to tell from the photos but it looks like the casing is plastic = cheap
and the dial/pointer look quite cheap to me.
you can see in one of the enlargements that the front screen is perspex = cheap.
no doubt handcrafted from the finest plastic by 5 year old chinese urchins.
(remember you usually get what you pay for).
If it were me, I would avoid but it's your money so do what you want.
SeaBass
| posted on 23/10/08 at 10:57 AM |
A little harsh maybe... Most of the interior of a modern car is made from plastic... The white surround is confusing me a bit though I have to say...
And are you sure they're free worldwide postage or just US?
madmandegge
| posted on 23/10/08 at 12:08 PM |
I knew they were cheap when I found them, thats why I decided to name them locost
But I thought if they were mounted properly, maybe behind a dash, they'd certainly be protected and probably work quite well.
The postage is indeed free to the UK, I use paypal to pay for stuff, have bought loads of things off them. Delivery does take probably 1-2 weeks, but
as it's free I've never had any reason to complain.
| posted on 23/10/08 at 01:15 PM |
fair enough, just put me down entirely as one of the guys that will not be happy with the quality of these.
James
| posted on 23/10/08 at 03:55 PM |
As is most of the bodywork of most of our cars!!!
I think they look relatively high quality personally, you can garantee that most modern cars will have predominantly plastic gauges!
What I don't like is the white bit that covers part of the face. But that's just a matter of personal taste.
James
- Muhammad Ali
Mix
| posted on 23/10/08 at 03:59 PM |
Hi
In fairness, I think you'll find most gauges available new nowadays have 'plastic' bodies.
Heh!! add lightness and all that.
Regards Mick
Danozeman
| posted on 23/10/08 at 04:43 PM |
AS this is Locost builders they would fit the bill nicely if your on a budget..
Dan
whitestu
| posted on 23/10/08 at 07:05 PM |
I've got a similar tacho that lights up when switched on, but is black with power off.
Its fine at night but competely useless in the daytime, as you can't see it.
Not saying these are the same but personally I think they will be.
Stu
