pinto
| posted on 23/11/09 at 02:45 PM |
Help Ford sierra cosworth style alloys
Can some one help thought these were Ford sierra cosworth alloys
now been told they are not because they are 14inch
what ford are they off
they are mine buy the way
thanks
link
| posted on 23/11/09 at 02:57 PM |
IIRC CossEH alloys were 15", the 14" ones were from Fiestas and Escorts (RS Turbos perhaps)
big_wasa
| posted on 23/11/09 at 03:05 PM |
14" was only the 90 spec xr3i and they where optional fit at that.
| posted on 23/11/09 at 03:41 PM |
The offset will almost certainly be different as well being for FWD Ford rather then RWD
big_wasa
| posted on 23/11/09 at 04:52 PM |
I dont know about the cossie but standard sierra is the same as the front wheel drive around 35~38
Mr G
| posted on 23/11/09 at 05:12 PM |
I saw your post yesterday and though I hope they are cosworth ones as you hav'nt said what size they are! (second most important bit of
information when selling wheels after what PCD they are and fit)
As posted above the 14" items where on the 3i's
C
Sapphire cosworth 'cross spokes' only come in the 15" flavour
pinto
| posted on 23/11/09 at 06:05 PM |
Just had a closer look at the wheels
and they have 6jx 14 x 35.5 and ford embossed on them
i now the 6j and 14 but what is the 35.5
how do you find pcd is it center to center across wheel
Blackbird Rush
| posted on 23/11/09 at 06:27 PM |
The ebay title describes them as xr3i, sierra cosworth style alloys....
robinj66
| posted on 23/11/09 at 07:18 PM |
If you google "Sierra Cosworth" and look at images, there are a couple of cars with those wheels on.
You might get a more definitive answer on one of the many Ford forums around.
[Edited on 23/11/09 by robinj66]
Mr G
| posted on 23/11/09 at 07:38 PM |
Yes it does NOW, the op has added that info
| posted on 23/11/09 at 09:08 PM |
The 35.5 is the offset which refers to how far offset the mounting face is from the centreline of the wheel. Important for keeping the wheel/tyre in
the right place track wise and rubbing on suspension or bodywork and over stressing the wheel bearing.
They're definitely Ford rims so the PCD will be 4 x 108mm - i.e. if you draw a square with the bolt hole centres at each corner each side of the
square will measure 108mm.
(Hope I'm not teaching egg sucking here )
Antnicuk
| posted on 23/11/09 at 09:26 PM |
stock cossie wheels are 15x7 with a 40 off set. All ford wheels are 4x108 PCD.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
pinto
| posted on 23/11/09 at 09:31 PM |
Hi nick205
don't you mean measuring from corner to corner diagnoley
| posted on 23/11/09 at 09:55 PM |
Hi nick205
I stand corrected so yes, I do now
(just looked in my old Zeus book of engineering measurements)
Puzzled
| posted on 23/11/09 at 10:10 PM |
got a set from a sierra. the pattern I believe is "LATTICE"
john_p_b
| posted on 24/11/09 at 10:10 PM |
the worst wheel in the world to clean! lol. takes me the best part of a day to clean mine when getting the cosworth ready for shows.
built a car, built a home, had a family. lost the family, lost the home, still got the car.
