Author: Subject: FS My HPA 4 wheel alignment set on ebay
nitram38
posted on 22/4/09 at 10:29 AM Reply With Quote
Link
Davey D
posted on 22/4/09 at 11:37 AM Reply With Quote
looks interesting! is it easy to use? prone to problems/failures. does it ever need servicing/calibrating?, and how big is the equipment?
im after some alignment equipment for the garage, but i cant decide on what i should get
mr henderson
posted on 22/4/09 at 12:31 PM Reply With Quote
Consider me one of the watchers
John
nitram38
posted on 22/4/09 at 12:37 PM Reply With Quote
It works!
It will take you a few hours to set up a new car.
philw
posted on 22/4/09 at 06:49 PM Reply With Quote
This is a must have! I recently bought a wheelforce (crypton) system and the difference it makes - well you can do everything - Toe, Castor, Camber, Front to rear alignment, rear Toe, Toe out on turn + more.
On mine it used to handle well but now it's amazing, before I would adjust something myself - then another thing needed re-adjusting by a garage with the right equipment at £20-£50 a throw. So although the initial outlay seems expensive you can adjust, try it - and then re-adjust if necessary for nowt.
It does take a few hours to set the car up, but when you can take it out and feel the difference the changes you have made make it is supremely satisfying
Must try harder
