bodger
| posted on 9/4/10 at 05:44 PM |
ALDI Bathroom Scales
Just noticed ALDI are doing 120KG Bathroom scales this Sunday for 3.99 ea. So could be a cheap option for doing corner weights if your car's
light enough.
Bluemoon
| posted on 9/4/10 at 06:05 PM |
always use two on each corner...
Ben_Copeland
| posted on 9/4/10 at 06:29 PM |
Just make sure they are accurate and not miles out !
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Mr G
| posted on 9/4/10 at 06:56 PM |
Those ratchet spanners they are doing are decent kit. I purchased the non flexi-head versions and they are very good quality. The amount of
'clicks' on the ratchet is obviously not as precise as the more costly halfords versions but definately worth the £££
G
ReMan
| posted on 9/4/10 at 07:58 PM |
eh?
loggyboy
| posted on 9/4/10 at 08:43 PM |
pop them on top of each other, measure each scale, add the 2 readings together. Means each scale takes half the weight, making 240kg per corner.
[Edited on 9/4/10 by loggyboy]
ReMan
| posted on 9/4/10 at 09:33 PM |
Surely the one on the bottom would measure the one on top + the car?
ashg
| posted on 9/4/10 at 09:37 PM |
side by side with bit of wood on top. but why bother.
you can get 200kg rated scales for £15 if you hunt about. not cheep when buying 4 but much cheaper than paying a race prep company to do it for you.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
