macc man
| posted on 9/5/10 at 09:46 AM |
balancing bike carbs.
A pal of mine gave me a set of gauges to balance bike carbs. Ther are no instructions for use included. Where do the threaded adaptors screw into on
the carbs? He thinks they fit on rubber hoses under carbs any thoughts?
| posted on 9/5/10 at 09:49 AM |
It depends on which carbs you've got Most have a balancing nipple (which will be capped off at present obviously) attached to them that you
attach the tubes onto.
macc man
| posted on 9/5/10 at 09:51 AM |
The carbs are Kawasaki zxr9. fitted to a zetec engine.
mistergrumpy
| posted on 9/5/10 at 10:14 AM |
On the ZX9 the take off points are on the block rather than the carb. You can see on
this guide. About 4-5 pictures down, the
exploded diagram. So you'd have to look more at the Zetec side of things or your adapter manifold that you're putting on I think.
Sorry I'm of no better help.
macc man
| posted on 9/5/10 at 11:30 AM |
Thanks for all the replys, iwill have a go this week.
