Author: Subject: Aldi's got welding stuff this Thursday
givemethebighammer
posted on 20/5/07 at 07:24 PM Reply With Quote
NTDWM
http://www.aldi-stores.co.uk/
Thursday 24th May
mangogrooveworkshop
posted on 20/5/07 at 07:28 PM Reply With Quote
need one for the workshop
ReMan
posted on 20/5/07 at 07:30 PM Reply With Quote
NTDWM
And I thought your middle name was Aldi
Macbeast
posted on 20/5/07 at 07:34 PM Reply With Quote
Is 130 amps good enough ?
damn! Forget it. I'm working day shift Thursday.
[Edited on 20/5/07 by Macbeast]
givemethebighammer
posted on 20/5/07 at 07:36 PM Reply With Quote
Originally posted by ReMan
NTDWM
It normally is, only I already have enough welding stuff to fix a battleship.
scottc
posted on 20/5/07 at 07:45 PM Reply With Quote
Is it worth getting a 'gas less' welder?
I've heard they can be a nightmare for beginners?
Keith Weiland
posted on 20/5/07 at 11:07 PM Reply With Quote
I don't think the welder is worth it, you get what you pay for and you aren't getting much for £99, plus I understand that gasless is messy. Some of the other gear might be worth a look.
speedyxjs
posted on 21/5/07 at 06:56 AM Reply With Quote
NTDWM
givemetheALDIbighammer
posted on 21/5/07 at 07:56 AM Reply With Quote
It's no harder to use than a gas setup IME, my first Clarke welder was a gas/gasless one and I was thankful for the gasless operation when doing work outside.
The welds and surrounding area do end up with a white coating of flux though, which is a bit of a pain to wire brush off, but the welds themselves can be just as neat as using gas. The wire is very expensive though (but v.good deal on wire at Aldi), and as the Aldi welder makes no mention of possible gas operation I'd give it a miss for anyone intending to build a chassis with it.
posted on 21/5/07 at 08:35 AM Reply With Quote
The thing that confused me with gasless welding is the diameter of the wire - it's usually slightly larger than plain MIG wire, 0.9mm instead of 0.8mm. I couldn't work out why it kept jamming! It worked OK after running a 0.9mm drill bit down the nose of a spare tip.
I found gasless to be very useful for occasional jobs, where it would have been silly to keep paying rental on a gas bottle - it's a lot of money when I was only welding stuff 3 or 4 times a year. It does work, but leaves a dusty white deposit around the weld. This is easily removed with a hand-held wire brush.
Now I have a CO2 bottle on which I don't pay rental so the gasless wire has been put away.
It may still get used for outdoor jobs though, as it isn't bothered by gusts of wind (not mine - the weather ).
I look upon it as a stick-welding substitute.
HTH,
