Anyone know what these would cost to turn up?
Doesnt matter what metal, as long as its stiff enough to swage 2mm ali under compression.
[Edited on 14/2/10 by MakeEverything]
What material? Do they need the flats on the sides?
Rich
Rich
Hmm, have you got a proper drawing? I may be able to turn it up out of aluminum for you...
I have turbocad too.
I have had a similar problem, i think it needs the autocad equivalent of the spline function, which smoothe the straight lines into curves.
Darren
