Decided to route one of the brake pipes using copper or similar from master cylinder to front t-piece, this is only going to be less than a metre
long.
Been looking for pipe and fittings and the inevitable search lead me to E-bay where kits are available for about £12 with M10 brass fittings and 25
metres of pipe - this is half the price of just the pipe at some other places! The E-bay shops are various generic motor factors.
So is this stuff any good? Has anyone used it? Or is a case of leave well alone and spend out?
Your thoughts?
Chris
I ordered my parts from Burtons. Personally I'd prefer to assume my brake fittings are from a reputable supplier....
Local Motor factor, you can see what you are buying. Our local one makes the tube to size with fittings, with no labour charge.
Copper pipe is not recommended you want Kunifier and a decent Flairing tool the best budget buy is the Powerhand or same tool under various differenr brand names. Quality of the unions (usaully called Tube Nuts in the trade) isn't an issue but how well made the flairs are if you want to seal first time.
Have a word with Oliver at Furoreproducts,
Link to FP,
he'll make you a flexy stainless braided hose for around £20, why bother messing about with copper or kunifer, the flexy is far easier to route
& clip up neatly.
Thanks for the reply, yes the flexi types do look good - will look into this.
When making brake pipes for my MK Indy I bought a reel of pipe (Copper IIRC) from my local motor factor. I formed the bends slowly by hand and used
my Dad's kit for forming the flares. The results worked perfectly and overall it didn't take long to do the job.
[img]
[/img]
