2 seconds after posting that I can not weld and wouldn't like to try, my brother calls me and says he's just bought an arc welder and
he's been welding for a bit now.
Anyone tell me if we can wels the locost chassis with an arc welder and if not why?
It's a 110 B.T.W.
I welded my frame with an arc welder.Dunno if it's good but it looks strong enough for my go kart
from what I have seen so far, it's a problem with the joint being messy but I would clean them up with a grinder anyway so that's not an
issue.
Is there any other problem? Strength of weld etc OK?
At the end of the day the difference in the strength of a weld from MIG or MMA (arc/stick welding) is nothing.
MMA produces a bit messier weld, covered in slag which you need to chip off with a hammer. Messy and takes ages. If you arent bothered about that then
theres no problem with arc welding.
I am an experienced arc welder, but I had difficulty in welding the chassis to the standards needed, mainly because of the problems of using the small
gauge rods needed for the job (1.6/2 mm). This may have been because of the cheap welder I was using, AC 50v. You really need a DC 80v machine for
this job.
I ended up buying a cheap TIG, which I am very pleased with, it also does DC 80v Arc. The only down side is the high cost of the gas.
Good luck.
RPS
MMA produces a bit messier weld, covered in slag which you need to chip off with a hammer. Messy and takes ages. If you arent bothered about that then theres no problem with arc welding.
Originally posted by Mark Allanson
Sorry, I cannot agree, the arc weld is about the neatest you can get, if you are doing it right, the slag will curl up and fall off about 1 1/2" behind the weld pool.
All sounds good guys thanks. I MAY have a chassis at a rediculously low price now so the welding would only be for changes!!
