This looks like exactly what I need, anyone wish to comment before I go ahead and order one?
http://www.pro-tools.com/105.htm
If you look on the Rorty design website you can make one very similar.
Hi I have no experience with that paticular pipe bender.
But PRO-TOOLS are a good company to deal with. Had a few things from them. Never a problem .
Cheers Matt
[Edited on 17/10/07 by procomp]
I'm sure you realise that this is a pipe bender rather than a tube bender, great for doing a roll cage but not for other bends you need to put
into ERW.
I hired a hydraulic pipe bender for a few days quite inexpensively. All the other bend, I made with the bending beam. I've shown this in my
archive.
John
John,
How do you stop the tube kinking with the bending beam?
Originally posted by Howlor
John,
I used a 15mm copper pipe bending spring inside my 19mm erw tube and made a wooden former to bend round.
Worked ok 4 me & others who have used it. £1.79 screwfix wood free.
The hole cut in the wood is a good fit for the tube at the sides. The bottom of the front side of the wood is chamfered so that the bend is made over
a distance rather than at a point which would cause it to kink.
The trick is to bend a little bit, then move the tube out towards you a fraction and bend a bit more. As you will see from my pictures, you can bend
round and square tube without kinking and to whatever radius you want. It really is a very simple and cheap way to bend tube. There is no need to fill
it with sand. All the bends on the Trials car were done in this way with the exception of course the roll cage for which I used pipe and a hydraulic
bender.
Please U2U me if you need any more information.
Best wishes
John
you can buy one for 22mm 15mm for £10 on ebay and for HYDRAULIC PIPE BENDER
15 + 20 + 25 + 32 + 40 + 50 + 65 + 80 mm its about £60
or just hire one ?
These pipe or tube benders work perfectly, on erw or cds thin wall or thick wall pipe or tube. Everything I have done is tube, cds or erw just use the
tube former and die for tube or use the pipe former and die for pipe. Dead easy to use and very quick.
Be aware by the time it gets to this country what ever it costs you in the States you can double that with carriage
and various import duties and VAT taxes
Hydraulic pipe benders the type you get from Machine Mart and the like are no good on Rollcage material unless you go to a heavy wall thickness, they
would be a lot better if they were available with tube formers that correctly fit tube though but still not ideal
You cannot do long curved bends with this. Only suitable for straight forward bends.
Originally posted by John Bonnett
I'm sure you realise that this is a pipe bender rather than a tube bender, great for doing a roll cage but not for other bends you need to put into ERW.
I hired a hydraulic pipe bender for a few days quite inexpensively. All the other bend, I made with the bending beam. I've shown this in my archive.
John
This was all bent on that model of bender...mostly 16g with some 14g..
Filling with sand is definitely NOT needed...
I didn't read this before my replies....I agree 100%
Alan
Originally posted by Minicooper@work
These pipe or tube benders work perfectly, on erw or cds thin wall or thick wall pipe or tube. Everything I have done is tube, cds or erw just use the tube former and die for tube or use the pipe former and die for pipe. Dead easy to use and very quick.
Hydraulic pipe benders the type you get from Machine Mart and the like are no good on Rollcage material unless you go to a heavy wall thickness, they would be a lot better if they were available with tube formers that correctly fit tube though but still not ideal
Now I live in the states I think I'm gonna buy the the dies from protools and build one myself like on the blind chicken racing site
Hey Liam....how are you liking it in the good 'ole USA?
Been looking at this type of bender for a while.
By the time you have a few extra dies ect along with the shipping costs, a grand isnt going to go far.
By the time you have a few extra dies ect along with the shipping costs, a grand isnt going to go far.![]()
I knew it was going to be a lot more expensive than the dollar price suggested, but it still looks like what I want.
I did consider the hydraulic machine mart type but even if I was lucky enough not to kink the tube it would still be difficult to get exact bends.
Here, they don't list prices but they may be worth a try. They do a direct pull and a ratchet bender.
Just to complete the picture,I've just received the Tubela pricelist and we are talking serious money for a hand operated tube and pipe bender.
For example, the model that bends 1/2" to 2" n/b pipe and tube up 90 degrees is £945.00 plus VAT and that is the cheapest in the range.
John
